Subaru WRX powered Mk1 Escort
  • #46
    Originally posted by 16vmini View Post
    hi , thanks,
    i get all your points , i need to have a think about what i will really use the car for ... will i need a boot etc , can i still have some sort of boot , even with rad in etc..
    i am still unsure on scoop in bonnet , but the bonnet is a patent , and the rear edge curve does not match the caar at all .. so i am also happy to ruin it by putting a scoop on it
    also if i go scoop to start with , its one less thing to worry about at the moment.
    Just trying to get it solid enough to bring her home ,as its "waiting at a mates" place
    i have come up with an idea for a rad fan setup , not sure if its crazy clever , or stupid yet .. but will show people once/if i try it...
    Matt
    rs 200 style and stick it on the roof
    • #47
      I hadn't thought of that!!!!
      with or with out ears ???
      good luck Matt
      Life is Racing......
      everything else is just waiting
      ...or buftying.
      • #48
        not done much recently / holidays / saving / buying stuff
        got chance to throw a seat in the other day , and good to see it fits and clears door posts etc ! :
        got some 2mm thick inner sills bent up , (upside down in pic)
        so need to work out seatbelt point and get this cut/fitted
        and also quickly cut up dash bar to re-fit :
        I have ordered up some roll cage parts , its a custom mk1 escort , but flat pack , and the legs have been lengthened ( just in case to i need extra length to reach subaru floor )
        that should arrive next week.
        welding a friends mini is getting in way
        • #49
          ok got the passenger inner sill cut and tacked in ,these are made from 2mm metal :
          created a new seatbelt point on sill aswell
          got my child to help clean the inside out a bit , :
          i did start on the drivers side inner sill, but got bored and wanted to see if the rear seats fit , they do ! :
          hope cage turns up this week , and have Wednesday planned off work , car is coming home soon !
          • #50
            Great project... Keep up the good/FAST work
            • #51
              plenty of leg room the back .....looking good sao far...ave ya got the escort shell all welded to the scooby pan??? what dash are ya gonna use???
              • #52
                going to use subaru dash i hope, thats my plan , want to keep as much as standard to the subaru . ( air con / heater etc )
                Matt
                • #53
                  ok , had day off work yesterday ,
                  made the decision to move the escort body 2 inchs forward ! , this would then give me room for a rad , but also make allot more other things line up , my only worry ( and still is ) is if i can make the front arches work :
                  but , look i have room for a rad and fan !! :
                  rear arches arnt a problem , as you can easily adjust position :
                  so i bit the bullet and fully welded the new 2mm thick inner sills , and started plating car up :
                  no going back now , will have to make front arches work
                  connected up fuel lines , bled brakes , and popped a drivers seat in ...
                  then was rude not to see if it moved !
                  its coming home next week ! will be able to do lots more on it !
                  • #54
                    Nice work mate, can you modify bottom arms to push the wheel further forward in the arch?
                    • #55
                      problem with that is you then effect the caster angles etc ..
                      simpler to try and lose it in the arch
                      Matt
                      • #56
                        roll cage arrived !
                        • #57
                          id hatew to think what a conversion of this size would cost if you had some body shop doing it for you .....looks pretty good
                          • #58
                            its home
                            now the real work can start...
                            • #59
                              ok first few days at home , first thing first , was to fix the clips on the end of the battery charger , been annoying me for years , and had some ready off a broken charger :
                              now , onto the roll cage ,
                              started by hole sawing some holes for the legs to drop into / through the floor
                              [IMG]http://lh4.googleusercontent.com/-n4QcG2YZ-jw/UZvUQexx4cI/AAAAAAAA***/SUfEpSjT4Ic/w1239-h929-no/IMAGE_CC72C31A-332D-4A24-894C-3E3149709F21.JPG[/IMG]
                              trial fit of main hoop
                              then did the same for the front legs
                              just incase no one knows , these holes will allow me to drop the cage inside the car for welding , then i will cover the holes with 3mm spreader plates.
                              never done this method before, but seen it on the internet
                              working on front bar angle to windscren pillar etc
                              mark twice , cut once
                              well actually i had to cut again after this .. but better to long then to short
                              some spreader plates for rear hoop
                              dont have any fancy tube notcher/cutter ... or space to setup pillar drill with hole saw , so i go old school and grind by hand
                              passenger side ready for tack , not sure to MIG or TIG at the moment.
                              need to do drivers side now , then i can work on front roof bar.
                              and just a quick shot of what i am thinking for rear bars
                              • #60
                                coming on well how are you sorting front wings modify a set of standard wings and position your existing bubble arches on wheel centre line and use back edge to infill ?
