Great pics,,well done to Mr Davis, I reckon a pilgrimage to the "Red Lion" is in order ! recreat the pic,,make a nice week end of that) Mine is going on a visit 2nd owner from the 1980s when its finished
My new MK2 RS2000
Originally posted by steve_26uk View PostGreat pics,,well done to Mr Davis, I reckon a pilgrimage to the "Red Lion" is in order ! recreat the pic,,make a nice week end of that) Mine is going on a visit 2nd owner from the 1980s when its finished
Got a little more work done over the weekend.
I removed the rocker cover to replace the gasket as it was seeping oil.
Then removed the exhaust manifold to replace the 4 gaskets as there was a noticeable blow out from one of them.
When I had them off I painted the manifold and rocker cover.
I had bright silver VHT paint and black VHT paint and neither looked right so I mixed a small amount of black wth the silver and produced a metallic grey. I also replaced the manifold to downpipe gasket as it was also leaking slightly.
Airfilter removed and rocker cover in need of rubbing down and painting.
Original cast iron manifold with heat shield removed.
Manifold removed along with 1 stud, engine block painted, then plugs replaced.
Thanks lads.
While I was working on it I also took the opportunity to put the original plates back on, theses plates were given to me by the previous owner and are the older type aluminium backed plate with the supplying dealer mark on them so I assume they are also the ones which were put on 30 years ago.
Still waiting on the V5 just to confirm I've been successful in getting the old plate back on.
Originally posted by Jethro View PostAll replaced... new plugs, new plug leads, rocker cover gasket, manifold gaskets,manifold bolts and new stainless rocker cover bolts.
The engine sounds so much much better now and is barely even audible above the exhaust noise.
dav
