Mk1gaz's new engine build
  • #76
    Thanks mate
    • #77
      SWEEEEET Gaz, sounds the berries mate!
      Look forward to hearing how the new build gets on
      • #78
        Cheers shifty . It sounded the tits before and that was with the small ports and 8x bent valves . It should sound even better and go faster now , i'll record some decent videos when it's done .
        • #79
          good lad gaz,will be mental for sure,cant wait to rinse ya on the way to the lakes buddy.i'll call you the weekend
          • #80
            No worries Piggy . Done some more spannering after work = cylinder head on , cam belt on , throttle bodies on , exhaust manifold on , then stoped as my backs fooooookin killing me !!!!!!!!!
            • #81
              Exhaust on , fuel pipes on , wiring on , water hoses on , oil return pipes on , coil pack on . I was pumping more old oil out from the return lines to the oil tank in the boot and then run out of oil . Need another 10 litres yet i reckon . Should be running soon though .
              • #82
                good work Gaz nearly there mate
                • #83
                  Should be out on Friday frying the tyres .
                  • #84
                    cool
                    • #85
                      Just got another 5 litres of shite out of the oil return pipe + oil cooler pipework !!!!! . The oils now comming out clean so i think it's now sorted . Going to fit the bonnet and radiator now and then fire it up and go out for a drive tomorrow .
                      • #86
                        Dont forget to clean the tank out
                        • #87
                          That was the easy bit as mine splits in half for cleaning . The rest wasn't very easy though and has taken at least 5 hours of reving the dry sump pump with a drill whilst pumping 10 litres new oil through the whole system .
                          Anyway SHE'S ALIVE !!!!!!!!!
                          • #88
                            mk1
                            Did you get it ready for tomorrow????????????????
                            • #89
                              Yes it's ready mate . I've been running it in over the trading estate etc for 3 hours and it goes sideways in 3 gears even at 5500 revs !!!!! . It sounds evil as fooooook , wait till you ear it at full chat on Youtube next week .
                              • #90
                                Nice one Gaz
