Hi folks , i'm getting my engine re-done at present as i want to get some more performance from it (plus the blocks cracked in 3 cylinders !!!!!!!!!)
Atmo cossies/16V pintos are ace and easy to get great performance from so watch this thread to see what you need .
I'm happy to answer any questions and won't go all secret squirrel on you so feel to ask anything and i'll do my best to help .
. There's thick mayonaise blocking all the pipes , coolers , breathers etc etc so i hope it's not ruined the crank and rods with any oil blockages etc . Hopefully they're ok and can be re-used again but we'll see . As my engine is high compression the new 205 pinto block will be an exact copy of the old one (bore size , deck height etc) . The pistons stick out of the block and just miss the valves so any fooook ups will prove costly . I also have escort cosworth oil spray jets machined into the 205 block too cool the undersides of the piston crowns . This also helps lubricate the gudgeon pin areas as this can be a problem area with premature wear . Some tuners drill a hole in the con rod for this but the oil spray jets are better .
