MKII Escort Rallycar RS 1800 Gp 2/4 specification
  • #46
    car
    Very nice mate, hows the car coming along?
    regards john
    • #47
      fasinating thread , please keep us posted ..........
      • #48
        regards john
        Sadly it have been a standstill here for a while , but IŽll give it a go trough the winter. These videos was a little booster actually.. !!
        Started to puzzle a little bit with the ZF gearbox here the other night, thinking of putting toghether a spare one. Will try to make a suitable input shaft out of a Fiat 130 ZF input shaft(and box) welded toghether with a bit of a Ford T9 gearbox input shaft. Will try to take som pictures of it .
        While taking measurements for this , I found out that one of the layshaft bearings on the ZF motorsport box had some damage , so IŽll have to open it to check...fingers crossed for the best... .
        Best regards Jorn
        By the way, I would like to mention that I enjoy this forum very much and I find a lot of good information in text and pictures .
        The Basket Case's, Restoration's and Ongoing Projects threads also contains many fine projects, and I would liked to give more comments and feedback on the respective threads, but time for this is not always available and having english as my second language makes me a rather slow writer whoŽs not allways understanding how you think out on the island in the North Sea.. !
        • #49
          Jorn The input shafts are being re manufactured for the ZF Box, give Phil or Mick Squires a ring at RACE in Stoke on Trent. Great thread keep it coming
          • #50
            The pedalbox have seen a lot of use and abuse and could do with a reconditioning.
            The clutch pedal seem to have taken som beating..!
            So I pulled it apart for some new parts and paint.
            Seems to be a Gartrac supplied box..?!
            Started making a replica of it too... .
            • #51
              keep at it, good interesting stuff there,
              • #52
                Found this picture in a Robson book, I will be aiming to replicate the interior of my car to something similar.
                Bought this two new P-lights, but from the picture I will need some more of them.
                This is the input shaft IŽm making out of a Fiat ZF box one and one from a T9 box.
                Made myself a service fixing/mount for the ZF box out of a wheel bolt from a M.A.N truck...
                Now it is serviceable, right..?! Found something worrying in front off the Motorsport box when taking off a cover, but will be back later with info on that....
                • #53
                  Interior shot is definately a 79 car as this was a typical 1979 layout for the interior of a Boreham escort, with the additional control box on the navi side.
                  Keeping you busy - keep it coming
                  • #54
                    Great work there mate!
                    Nice to see pics and video too!
                    Keep up the good work!
                    • #55
                      Plenty of P-lights out there, if you know where to look...
                      Finishing off the ZF box cover with two M8 bolts on top and made a steel lip for connecting to the shell(placed here with self tappers).
                      Welded trough the holes and then under afterwards.
                      Cut-out, giving room for possibly a watt-link.
                      Shaped and stitched up a piece of steel.
                      • #56
                        One more video of the car...
                        • #57
                          Double floorpans....
                          I thought the best thing was to cut them out!
                          Continued with the rear floor as well.., making room for the new chassis rail. Now it gets interesting...
                          • #58
                            The pedalbox fabrication is also coming along quite OK..!
                            Fabricated pump mounting bracket.
                            Here mounted on a original mk II pedalbox housing.
                            Modified brake pedal.
                            • #59
                              I have cut away the metal bits that was left from the old chassis rail and then adjusted a new one into place.
                              After welding it in, I started fitting a new floor pan...
                              The threads on the old gearbox mountings werenŽt any good, so they needed to be replaced. Welded up an old crossmember to keep the position right.
                              Luckily I had replacements lying around .
                              More work is waiting...
                              • #60
                                Some excellent fabricating being done here, a really interesting thread.
