Project Yellow
  • Originally posted by rallyreturn View Post
    Sorry , they are for the Mk1, Mk2 inserts are here
    http://www.motorsport-tools.com/esco...-p-267829.html
    hi
    thanks for the link m8.
    ur getting there with ur car.be worth it in the end .
    will keep watching ur progress.
    dav
    • Managed to finish off the spare wheel well today and started to fabricate pieces of metal to repair the quarter panel to arch filler.
      Uploaded with ImageShack.us
      • Coming along well, top work, wish I had that skill
        • Finished off the quarter panel today, just needs filler to finish.
          • just found this thread,, you will do for me,, you are gettin well stuck in to that resto, it will be a good strong tub when ur done ( hope that jig made life easier )
            is it for use and abuse, , or is it gettin the bufty treatment ,
            either way keep on at it and you will soon be sideways on the black stuff
            ,,,,it will be reight when its done
            • hi
              comeing on a treat m8.
              keep up the good work.
              dav
              • Originally posted by mk2mania View Post
                This one is to be used and abused in the forests of Wales, (be a while yet though).
                Couldn't have got this far without your Jig, especially as I'm having to build in such a confined space, highly recomended, although I have broken 2 location shot bolts so have resorted to using an 8mm allen key which works a treat!!!!
                I'll be looking to buy one of your shell movers....... http://www.ebay.co.uk/itm/ESCORT-MK1...item4cfbb7be15
                If your feeling generous and fancy giving me a repeat customer discount then please contact me.
                • Originally posted by bluevan1 View Post
                  Thanks Bluevan, appreciate the encouragement.
                  • Just dont bend it after all that work
                      Made a start on the other side today, cut out loads of metal and cleaned up the turret area.
                      You've got some metal work skills there. What tool do you use to cut the bad metal out?
                        we always try our best to look after our punters,,if you need one give us a bell,, cheers rick
                        • Originally posted by havard01 View Post
                          I'm using a Dewalt 4 1/2" angle grinder with 0.8mm thin metal cutting discs from Screwfix. for awkward areas I use a Dremel type tool with metal cutting discs, also use it to grind down bad welds in tight areas.
                          • Welded in the radiator surround today, managed to seam weld it underneath except for the gussets, just needs some seam sealer along the top edge to make it look neat.
                            • Wasn't sure if I was going to fit these wing Gussets that came as part of a shell plating kit but they look ok, what do you think!!!!! can always grind them off.
                              Also managed to weld in the rear valence skid plate.
                              • hi
                                nice work m8.
                                neat job.keep at it.
                                as for ur cussets they look fine.if ur going to rally or track ur car it will stop ur car flexing .and keep ur shell strong .
                                dav
