Front panel tacked on but slam panel requires quite a bit of fettling to get it to fit right. Seems to be sloping forwards, does anyone know if it is normal for the slam panel to do this!!!!!!!!
Waiting for the righthand side wing rail as they are out of stock at Hadrian but I'll butt weld the left side and test fit the bonnet and wings.
good to see some progress there m8 .
and pics .am sure it will fall together once u fit ur wings etc.
a screw eveything to gether to make sure everthing lines up works for me .before a do any welds .
but everyone works there own way tho.
Trial fit of front end, minus wing rails, not too bad ,just a bit of fettling of the wings but that was no suprise. Difficult to get better pictures as not much room in my garage!!!!
Time to work on the back end, 1st job is to replace the ugly diff tunnel. This is typical of the problems I'm coming across, having to redo shite work, it would be a lot easier if it was a standard shell.
Still needs a few more hours to weld some pin holes and dress the welds. Should look okay with a skim of filler here and there and some seam sealer on the joints, quite pleased with the outcome, and much better than the diff tunnel that the previous owner fitted.
Started to tidy up under the rear wheel arches, as these are rubbish as well.
cracking work going on there buddy,always harder to work after others have bodged,funny to think of all the escorts sat in garages we dont know about,your about 10 mins from me, somewhere,keep at it
