Originally posted by mk1gaz
						 . Plus all of us had to find out things by asking others so don't be shy . Besides an engines an engine so they're all the same (except 2 strokes and rotary's)
 . Plus all of us had to find out things by asking others so don't be shy . Besides an engines an engine so they're all the same (except 2 strokes and rotary's)  .
						 . Here's the bottom end before final strip down . It's full of mayonassie where the oil + water have mixed
 . Here's the bottom end before final strip down . It's full of mayonassie where the oil + water have mixed  .
  . The new 205 block is ready to go to Julian Godfrey's place for machining on Monday (block decked , oil spray jets fitted , rebore , chemical clean etc ) . The crank , rods and pistons are all being checked and measured so i'll find out soon if they foooooked or not !!!
 . The new 205 block is ready to go to Julian Godfrey's place for machining on Monday (block decked , oil spray jets fitted , rebore , chemical clean etc ) . The crank , rods and pistons are all being checked and measured so i'll find out soon if they foooooked or not !!!  .
  , so the turbos better watch out !!!!! .
