Mk1gaz's new engine build
lol , ear muffs are the way forward more like !!!!!!Originally posted by pinto48s View Postdo the alternators vibrate apart?
welding the through bolts helps!!
exhaust is nice, under axle is the way foreward.
got a 2 1/2 inch system and prepfab box on my pinto and that aint quiet either
I used to smash the alternator casings at the top but got a Gartrac nylon tension arm and that cured that problem . Now it's the 8500rpm gear changes that kills them and they just stop working after a few miles . The new bigger pulley should slow the alternator down now so they should last a few years (pray)
Cheers Andy , sounds better (and louder) in real life . I scattered all the foxes out the park on saturday night as i went past . About 10 of the buggers ran out in one go holding their ears , lolOriginally posted by Andyc View Postthat sounds lush
It's shiney like a mirror , i may spray it satin black as it makes everything else look old .Originally posted by Darran View PostClever boy is Toby.
You'll be a buffy boy let mate....
The only problem Gaz, is that if you do end up doing a track day it'll probably fail the sound check the way things are going as all circuits are put under more pressure to reduce noise - load of crapOriginally posted by mk1gaz View PostCheers Andy , sounds better (and louder) in real life . I scattered all the foxes out the park on saturday night as i went past . About 10 of the buggers ran out in one go holding their ears , lol
Sounds good though
Well if it did pass a noise test then there's hope for everyone . No chance if the truth be told , the trumpets are 200 decibels without the exhausts 200 mixed in . Concords quieter !!!!!!
An action shot from RetroFord mags new Facebook page
V8 M3's are trailing in the dust !!!!!!
I've had a slight problem getting the rings to seal properly since the last alternator broke . On a fuel injected car if the alternator fails the voltage dropping from the normal 13.8volts down to below 12volts causes massive overfuelling and eventual bore wash . I drove mine over 100miles with it misfiring and overfueling like fooook last month as the RAC refused to tow me home from the M1 as the car's modified
(tossers) . Anyway i've stripped the engine and found this so i will be getting the bores re-honed this week and fitting it all back together ready for next weekend .
Ha Ha FPMSL , that's a great idea .
. All my cars are always modified and it's the 1st time i've been refused a tow home by them in 15 years . Think i just got a jobsworth patrol man on his way home after a long shift or something
. I'm blamming him though for my polished up bores .
Anyway i've shown the engine to the engine man and he reckons it's alright and not fully run in yet . So putting it back in the car ASAP and then getting the external oil pump checked out as it may not be sucking enough oil out the engine at high RPM
. So the RAC man is off the hook again
Engine is back in again so i now need a £150 head gasket
and a £400 dry sump oil pump
Too true except i got a shirt that don't fit !!!!!!!Originally posted by Andyc View Postwould of been a nice birthday prezzy
