rolling roads
Don't worry mate , most rolling roads don't bother getting the air temps correct and this makes them look better when they give an engine a power run afterwards !!!!!!!!Originally posted by richy c View Postspoke to slark speed today,the figure i put up was wrong
but i didnt know.the correct figure is 148lb. which is still good
. the reason for the high figure is to do with there air temp sensor or something.so sorry for the mix up(why am i saying sorry?) GJ ITS YOUR FAULT
Oh, and as someone has allready mentioned .. stroke plays a part in the torque curve .. and as F1 engines have a stroke of less than 40mm thats why they dont make high ft/lb per litre figures, but they do rev to 19,000 rpmOriginally posted by mk1gaz View PostBlimey , less than all these 4 cylinder 2.3 duratecs then
(or so they reckon) .
And we are not going to get into the "cheating debate " about turbos.. they are legal ..
148lb is a good figure richyOriginally posted by richy c View Postspoke to slark speed today,the figure i put up was wrong
This 16v pintos got some torque
. It's not even had the cams phased yet for the big "peak" bhp pub numbers
Lol , 180bhp at the wheels on pump fuel and it drives niceOriginally posted by Darran View PostMade good pinto power, that cossy mate
. It should blast into the 12 second 1/4 mile bracket at the retro show (on street rubber and without any bits missing of course)
And makes 85.5 ft/lb per litre ...
If anyones got a rolling road graph .. what about putting up your ft/lb per litre figure here .. thers loads of Pintos and x-flows in members cars, so we could have a good average from lots of engines and rolling roads.. this will give you some indication on ...
A; How good your engine really is
and
B; how close to average your choosen rollers are.
Call it a little Forum experiment
Engine .................... cc...................... ft/lb / litre
NAME...............ENGINE.................... CC ........................ FT/LB / LITRE
Darren .............HT pinto ...................2.2 ......................... 78.18
Darren's mate ..HT pinto ...................2.1.......................... 75.2
Mk1Gaz........... NA Cossie YB .............2.0........................... 85.5
SBD ............... Duratec.....................2.0................... ....... 97
AndyPipe.......... HT X-flow.................1.6 .......................... 73.3
Cossimatt ........ SBD YB. N/A ............. 2.0.......................... 74.85
Pushrod............X-flow...................... 1.7 ......................... 82.9
thats just a few i know
Added.Originally posted by gary@retro View PostNAME...............ENGINE.................... CC ........................ FT/LB / LITRE
TimGR...............X-flow.......................1.8.................... .......77
This is simply not true, a turbo "effectively" increases the engine capacity and therefore if used in motorsport is given a multiplier if competing against n/a engines, as the "compressed" air equates to an increase in the swept volume in a n/a engine without "compressed air"Originally posted by mk1gaz View PostNo it's not , a 2 litre is still a 2 litre but it will get fed more air if a turbo is slapped on it so the bhp + torque will go up not the capacity .
They only have different race classes because a turbo is a power adder and therefore cheating !!!!!!!!
Yes rwdrs but a turbo is still a "power adder" and thus increases power and torque cos it stuffs the engine with extra air which it wouldn't normally recieve .
lol this is good except for one tiny thingOriginally posted by gary@retro View PostAnd makes 85.5 ft/lb per litre ...
and
. NOT ALL ROLLING ROADS ARE EQUAL . Dyno-dynamics runs only please
Rolling roads may lie BUT CLOCKS DON'T
. Here's a full weight and comfy street legal mk1 escorts time slip (0-105mph in 13.4 secs) running on a cheap set of 175mm wide Yoko A539's . This is on the first attempt with only 215 dyno-dynamics bhp , it will run into the 12's next time out
