5 Speed box or not
  • #31
    kev, does fifth gear come in handy as you load it on the trailer???
    • #32
      5 speed in mine as well. Removed the plates by carefully drilling the spot welds out, soldered the old holes up on the tunnel and bolted the plates in their new position. With a little welding I can go back to a 4 speed if I want, but I can't see myself doing that. Use a 5 speed gearknob from an early Sierra, it's similar to the RS 4 speed one. The type 9 cuts the revs down, saves engine wear, reduces petrol consumption........what more can I say.
      RS2000EXPRESS
      RS Mk2 Club 099
      • #33
        Right 2.8 5 speed going in
        • #34
          Originally posted by DazRS2K View Post
          What is a type 9 gearbox? and what is the difference between a 2.8 one?
          Mine has a four speed in, and just spoke with Hally about it, and he said 5 speed is better?
          CheeRS
          Daz
          pic of a couple of Type 9 gearboxes.............................
          • #35
            i think your right m8...it looks like the way to make the car better to drive
            but you have got to have the right diff
            what is the best diff with the 2.8 box then...........?
            • #36
              Isn't it just the first gear ratio that's different and the length of the input shaft, but I'd say ideal for the road is surely the 3.77:1 a 3.89 just negates the 0.82:1 overdrive top of the type 9 AFAIK
              • #37
                I have a type 9 with a 3.9 diff in my red RS and the gearing seems fine. But the 2.8 box will be going on to a 3.54 standard diff.
