Originally posted by Mogsmex
5 Speed box or not
I must get a type 9 for mine, for long trips the 4 speed is too noisy, and Autobahn speeds are a tad higherOriginally posted by Dermot View PostThought about changing it a while ago, but the 4 speed is still good enough.
Better shift, although it does make for a bit of engine noise at motorway speeds.
''''''''Averaged 11mpg on the Lakes Tour...Originally posted by Frosticles View Post2.8 Box here and a great addition. Has all the "RS" ratio's as the 4 speed with the overdrive 5th so perfect. Thing is, Now with a 3.9 LSD still rev's its tits off like the 4 speed used to....
Good job you got the 5 speed Kev, otherwise the 4 speed would give you 7 mpg instead of the whopping 11 !
