kev, does fifth gear come in handy as you load it on the trailer???
5 Speed box or not
5 speed in mine as well. Removed the plates by carefully drilling the spot welds out, soldered the old holes up on the tunnel and bolted the plates in their new position. With a little welding I can go back to a 4 speed if I want, but I can't see myself doing that. Use a 5 speed gearknob from an early Sierra, it's similar to the RS 4 speed one. The type 9 cuts the revs down, saves engine wear, reduces petrol consumption........what more can I say.
RS2000EXPRESS
RS Mk2 Club 099
Originally posted by DazRS2K View PostWhat is a type 9 gearbox? and what is the difference between a 2.8 one?
Mine has a four speed in, and just spoke with Hally about it, and he said 5 speed is better?
CheeRS
Daz
pic of a couple of Type 9 gearboxes.............................
cheeRSsigpic
Isn't it just the first gear ratio that's different and the length of the input shaft, but I'd say ideal for the road is surely the 3.77:1 a 3.89 just negates the 0.82:1 overdrive top of the type 9 AFAIKOriginally posted by RS2000&MEXICO View Posti think your right m8...it looks like the way to make the car better to drive
but you have got to have the right diff
what is the best diff with the 2.8 box then...........?
