OFE 800V's ==ITS NEARLY THERE 09/05/05 = p12
  • So what's that stain on the rear seat then, eh?
    BTW, used to have a mate at university who was about 7' tall and drove a mini with the front seat mounted where the back seat used to be!
    • its just your dirty mind playing tricks again lol
      • had a play this morning nothing better to do so took the back end off, whats a pig without a ramp
        As you can see the floor is very sound hardly even surface rust under there, nice original colour and all it needs is a clean off, the old waxoyl, but should I get it painted or leave well alone ? dont want to make a dogs dinner of it, as I like originality if its there to be kept
        only the boot floor has surface rust in small patches as you can see
        Brian
        • > but should I get it painted or leave well alone ?
          shouldnt you of decided that before you sent it to the painters
          i'm in the same situation as you Brian (apart from a car in bits)
          on one hand i'd like to paint the floor (dove grey) on the other I want to leave it well alone and cover it with wax[/img]
          • Have it painted mate
            • Yes Topaz
              probably should have but then this only started out as a lets clean the engine bay and wheel arches, and now look whats happened.
              I shall paint all the axle and bits and think about the floor, for a while !!
              as too comments I have had re the over spray on bits a bobs, there was so much waxoyl everywhere the paint has not stuck to anything it all rubs off with a cloth
              • If it were mine I would sort out the surface rust spots on the boot floor and paint it Dove grey so the underside is nice, then spray it with waxoyl over the top of the Dove grey - you can always wipe the waxoyl off with parafin later - If you stone chip it and paint it body colour (for example) then it's not something that's easily changed at a later date.
                Cheers Rob.
                www.RWD-Escort.co.uk
                • Decided after a dicussion that I'm just going to treat the areas and keep the original ppainted parts then waxoyl again, maybe last another 25 years like this TOUCH WOOD
                  • Block now painted and the front pullies will be cleaned up too new feul pump oil filter and clean dizzy with aldon ignitor
                    • no pics there brian is it my pc..??
                      sigpiccheeRS paul
                      • I can see it
                        • i carnt...??
                          sigpiccheeRS paul
                          • Looking good, how are the front struts coming on ?
                            • Heres the axle casing now been 2 packed nice
                              • that looks very nice brian......
                                now get on and finish her....lol
                                sigpiccheeRS paul
