Escort Mk1
10
11
12
13
14
15
perry oaks
Nov 2015
22-05-2018, 06:40
Front Struts converted to Coil Overs
perry oaks
Nov 2015
22-05-2018, 06:41
Test fitting the engine and gearbox
Fitting a Focus ST170 engine
Some custom fit engine mounts are made.
perry oaks
Nov 2015
22-05-2018, 06:41
Mated with a type 9 gearbox
As the gearbox is longer that the standard escort gearbox - the gear lever hole needs to be moved.
And needs the existing gearbox mounts to be moved
perry oaks
Nov 2015
22-05-2018, 06:42
perry oaks
Nov 2015
22-05-2018, 06:42
Test Fit the Exhaust
perry oaks
Nov 2015
22-05-2018, 06:43
Rear Valance needs some adjustment
perry oaks
Nov 2015
22-05-2018, 06:44
The car was then removed from the restoration Jig and moved onto a roll over Jig for the last few bits and pieces before paint
perry oaks
Nov 2015
22-05-2018, 06:44
Seat Braces fitted
perry oaks
Nov 2015
22-05-2018, 06:45
Clips to hold the rear bench seat in place
perry oaks
Nov 2015
22-05-2018, 06:50
Holes drilled for front and rear lights
perry oaks
Nov 2015
22-05-2018, 06:51
Parcel Shelf Brackets
perry oaks
Nov 2015
22-05-2018, 06:51
Fitting the wheels
The rear leaf springs have had the camber slightly to reduced to lower the car
perry oaks
Nov 2015
22-05-2018, 06:52
LSD!!
perry oaks
Nov 2015
22-05-2018, 06:53
Rear Axel
perry oaks
Nov 2015
22-05-2018, 06:53
The engine and gearbox are then removed and 'old' suspension fitted.
Off to Paint!
10
11
12
13
14
15
