Escort Mk1
9
10
11
12
13
14
15
perry oaks
Nov 2015
05-11-2016, 09:35
Using the replacement scuttle and a fabricated piece the inner scuttle is replaced
perry oaks
Nov 2015
05-11-2016, 09:36
Fabricated Inner Scuttle Finished
perry oaks
Nov 2015
08-11-2016, 04:17
Rear Parcel Shelf and firewall
Trimmed off the rusty metal from the donor shelf which left the exposed inner section, treated the surface with rust converter and left to sit for 24 hours, and finally sprayed with weld thru primer ready for fitting.
perry oaks
Nov 2015
08-11-2016, 04:29
Another piece of the jigsaw complete 78 plug welds and 6 stitch welds later the parcel shelf fitted like a glove.
perry oaks
Nov 2015
08-11-2016, 04:30
Next on the hit list to be repaired is the outer scuttle.
then rust treated and painted diamond white underneath.
Trimmed up the outer scuttle and painted with rust converter,,
perry oaks
Nov 2015
09-11-2016, 15:55
The rear scuttle turning black - this is a sign of the rust converter doing its job,,
Fuel Filler Neck
Yet another repair bodge!
perry oaks
Nov 2015
09-11-2016, 15:56
perry oaks
Nov 2015
09-11-2016, 15:57
Trial Fitting of the fuel tank
All mounting holes actually line up even after all the shell realignment.
perry oaks
Nov 2015
19-05-2017, 19:52
Door Repairs
Two new door skins from NHC Panels
perry oaks
Nov 2015
19-05-2017, 19:52
Removing the old skins exposed over 40 years of water damage and rust!!
The strengthening strut brace across the door also showed signs of corrosion
So has been replaced.
perry oaks
Nov 2015
19-05-2017, 19:53
One of the doors only needed a patch across the bottom
The other door required the entire bottom to be replaced - a section was cut in order to reproduce the profile.
To be welded in the door
perry oaks
Nov 2015
19-05-2017, 19:53
LOUIE
Aug 2006
19-05-2017, 21:22
Some great work there, keep them coming
perry oaks
Nov 2015
02-06-2017, 18:10
The drivers side frame repaired and then rust treated
Then two pack primer and coloured white inside and ready for the final fit of the skins,
perry oaks
Nov 2015
02-06-2017, 18:12
Along with the door sills
Drain Holes added -
9
10
11
12
13
14
15
