Escort Mk1
It is great, could really do with one for my refurb. It could do with a new floor but without a jig not keen to go that route so will do the floors either side of the tunnel with a half floor panel from express.Originally posted by perry oaks View PostThe jig is absolutely brilliant - its purpose built for escorts.
More fantastic work chap. Keep the updates coming.
Whilst test fitting the rear panel its noticed the central support bracket for the rear panel - the one that holds the rear latch - is not central.
One of the drawbacks of pattern parts - i guess!
The rear boot latch is located on this support bracket and unfortunately there isn't enough adjustment in the boot latch fitments, so when the boot lid is closed it pulls the lid across to one side, so the support bracket will need to be removed and moved across 10mm.
Zoom in to the rear panel - the panel center line is the blue line - the spot welds for the rear panel support bracket are also highlighted.
From the inside - the support bracket should line up with boot floor pan.
This is the new pattern part
And this is an original
I think this will get greater exposure here, so here is a blatant beg for parts!!
Is anybody cutting a Mk1 shell or arching a shell
I'm looking for decent condition wheel tubs for a Mk1 Escort. (both sides)
terrynutty@gmail.com
Thanks
Thanks for replying - Express can produce them, but they are quite costly (they are hand made - in their defense!), but the big problem is the three month lead time to produce them.Originally posted by LOUIE View PostExpress panels not doing them?
Or try Roy nunn
Magnum have said they are going to start producing Mk1 tubs - but not for a couple of months.
My car is sitting in bits on a Jig - got about a week or so of work before I need tubs!!
I'll try Roy Nunn - would you have any contact info for him - tried googling!!
Thanks again
Originally posted by perry oaks View PostThanks for replying - Express can produce them, but they are quite costly (they are hand made - in their defense!), but the big problem is the three month lead time to produce them.
Thanks again
I'll have a look pal, got it somewheresigpic
