Escort Mk1
  • With the repairs to the bottom of the inner part of the door.
    And door drains drilled
    • The inner part of the door and the new door skin are prepared in two pack primer and coloured white inside
      The new door skins are fitted.
      • The new door skin is tapped into shape around the inner part of the original door shell.
        And blended in with the original door
        • Next the seat belt anchor plates are welded to the floor pan and will eventually be covered by the sills.
          And then primed
          • Fitting the Doors and door shuts!
            Again due to previous bad repairs the striker plates need sorting.
            • Comment
              • Doors Fitted
                • Both Sills replaced
                  • Anti-tramp bars Fitted
                    Brackets welded to the axle
                    • Painting the bits you can't see!!
                      Under the heater bubble
                      Then the heater bubble welded on
                      • Under the scuttle panel
                        The the scuttle panel welded in place
                        • Seam Sealed
                          • Comment
                            • Inner Wings and inside of Wings Painted
                              • Inside of the door shell also painted
                                Wings finally welded in place
