Looks Really Well Mark, Bet Your Well Pleased So Far :d
mk2 mex resto.
latest pics for you.........
petrol tank in.....
fiesta battery tray mounted in spare wheel well, battery in and new cable made up to run the length of the car..........
back bumper and badges on..............
round to the front now and bias pedal box fitted..........
engine bay loom in place........
front bumpers, lights and indicators on..............
fitted some bilsteins with lowered/uprated springs........
alloy top mounts, quick rack,new track control arms fitted........
next jobs will be fitting heater, wiper motor and all the wiring under the dash, then i can
think about dropping motor in.
got some good un-cut door cards now, still needing back seat and carpet.
cheers.Last edited by Mark M; 21-07-2006, 22:15.😯
update on last few days work.............
hired a hoist........
half way in.........
and in...........
fitted new plugs and leads, new coil and luminition kit. fitted exhaust manifold and carbs........
clutch cable,speedo and throttle cables on........
changed oil and filter, primed her with fuel and fired her up. well pleased as she barked in to life.didnt expect it as i kind of guessed with the luminition wiring. no exhaust system on yet so was a bit noisy.
need to sort cooling system out too.
fitted heater, wiper motor ect. all under dash stuff done.
wiring wasnt too bad, easier than i thought. only had a small problem with a bad earth on rear lights, but fixed now. wiper motor would not work at first, kept blowing fuses. traced to bad motor. had another in the shed, swapped it over and now everthing works.
fitted 3 spoke and home made boss, clocks, glovebox ect.....
will try and get carpet in tommorrow, and a few other little jobs done.
cheers.😯
Originally posted by RS2000&MEXICOshe is looking well mint there mark i bet you carnt wait to have a drive now....😯
update for last few weeks....................
fitted front spoiler and some spot lights (number plate now removed and put on straight after these pics.......
bonnet on..........
fitted peter lloyd 2.25 inch twin box system.(fitted very well)
trim 99% finished...........
doors on.........
bit of free advertising for dave ..........
all left to do is give it a good clean, fit decals, save up for some front brakes, (hopefully off santa at christmas ) make up an engine breather and the washer bottle to fit. may get the rims polished over the winter, will have to wait for the credit card to recover first.
cheers.😯
