The 12sec "comfy" Evo 2 rebuild .
Cheers chaps , got decent compression on all 4 cylinders so i hope the uprated block can take it and last longer than the previous 205 ones did .
I've got a 2.5 litre alloy block tucked away just incase but hopefully it won't be needed on this engine .
I'll take some videos of the mapping/dyno session and when the roads dry out and trust me it sounds mental . Imagine a national hot rod x10 and you'll get the picture , lol .sigpic 2.1 ATMO YB POWER .
Originally posted by mk1gaz View PostCheers chaps , got decent compression on all 4 cylinders so i hope the uprated block can take it and last longer than the previous 205 ones did .
Hi John , got a 202 pinto block which is the same as a 200 block around the bores (thicker) . It should last longer than a 205 block but not sure how long . Maybe it will last forever and not crack but only time will tell .
The 2.5 alloy block will be used one day but very expensive if you use all the top notch bits inside it .
Wifey would kill me if she found out , lol .sigpic 2.1 ATMO YB POWER .
Got the car mot'd yesterday so it went for it's 1st drive . Sounds evil as fooooook but running a bit rough and needs mapping again due to all the changes . C0 at idle was only 0.4% so running on air at present . I'll increase the fuel pressure a touch tomorrow and take it for a spin as that should improve it for now .
Rollers soon .sigpic 2.1 ATMO YB POWER .
Got my free car tax on line just now (unlucky the mk2 lovers can't) lol .sigpic 2.1 ATMO YB POWER .
Originally posted by mk1gaz View PostGot my free car tax on line just now (unlucky the mk2 lovers can't) lol .
Ok folks , turned up the fuel pressure a touch for now until i can get to the rolling road and engine's now running pretty good . Been out in it everyday this week and no problems so far except the oil leak from the cam cover .
Should have done 500 miles by next week so then it's dyno time , BAAAAAAAAAAAARRRP .
I've been really good this time and not floored it once so looking forward to opening the taps next week . Even on minute throttle openings it sounds fooooookin evil and local pedestrians are shitting themselves when it trundles up the road , lol .
An engine has never sounded this good and trust me it will go like fooooooooook !!!sigpic 2.1 ATMO YB POWER .
