Well i decided to tweak the spec of the world famous 12sec "comfy" mk1 Escort early last year but progress has been very slow due to DIY projects + wifey taking all my money .
I stripped the car of all it's mechanicals and then it's just sat there gathering dust for 12 months until now .
Plans for the new Evo 2 version include a new 202 thick wall pinto block to hopefully stop the blocks splitting at 8500+rpm and 230x Dyno-Dynamics bhp (265+ "coastdown" bhp) , 50 kilos less weight , a line lock for big burnouts at the drag strip , lower gearing for more acceleration , sort the 6 pot brakes out with different brake cylinder sizes , sort out the front crank trigger set up and change the suspension a bit with coil overs on the front etc .
Hoping to go sub 4.0secs to 60mph and low 12secs at 110+mph over a 1/4 mile whilst street driven and street legal . Should be possible so we'll see what the FIA approved clock says .
I'll post some pics up soon and all feedback is welcome . Cheers .
I stripped the car of all it's mechanicals and then it's just sat there gathering dust for 12 months until now . Plans for the new Evo 2 version include a new 202 thick wall pinto block to hopefully stop the blocks splitting at 8500+rpm and 230x Dyno-Dynamics bhp (265+ "coastdown" bhp) , 50 kilos less weight , a line lock for big burnouts at the drag strip , lower gearing for more acceleration , sort the 6 pot brakes out with different brake cylinder sizes , sort out the front crank trigger set up and change the suspension a bit with coil overs on the front etc .
when i built my n/a engine didnt use either spray jets in the block or the cossie pickup pipe and everything seems to be holding together with the oil just splashing around
