Project Yellow
Stage 1 strip to bare shell completed, now the real hard work begins, Grinding, sanding and welding!!!!!
Uploaded with ImageShack.us
After 8 ltrs of Nitro mors and about 50hrs of tedious scraping the inside is more or less stripped of paint. Was well worth the effort as all the dodgy areas are now showing themselves, not too bad really just a small amount of rot on each splash panel which I'll repair with a few patches.
As you can see in the first photo the Diff tunnel has been welded to one side and not central, anybody know why!!!!!! is it for a reason or just a crap job. I intend to cut it out and fit a wider tunnel in the center.
Next job is to strip all the underside and see what else I find!!!!!!
THE DEEPER YOU DIG THE MORE YOU FIND!!!!!!!!
Going to fill in the heater cut out as a heated windscreen to be fitted and add a new lip to the bottom of the plenum chamber together with a new chamber assy.
Both Splash panels to be replaced, both wings and rails, complete new front end and slam panel due to passenger corner having had accident damage and a previous bad repair.
Not sure how much of this radiator mod to keep or replace, ANY THOUGHTS ?????
coming on well there mate, looks an interesting mod for the big rad...if your rad goes in no bother I may be tempted to just add in some gussets between the bars to add even more strength maybe...Its up to you though, certainly will be a fun machine when your done
Originally posted by SHIFTY View Postcoming on well there mate, looks an interesting mod for the big rad...if your rad goes in no bother I may be tempted to just add in some gussets between the bars to add even more strength maybe...Its up to you though, certainly will be a fun machine when your done
I've finally decided to build it historic spec and as a BDA or BDG is out of the question I'm going for a Pinto. I'll buy a rad for the Pinto motor, fit it and see what looks and performs the best.
This is going to be a Long project!!!!!!!!!!
Originally posted by maru_uk View PostCan I ask who you are? I recognise the car in your pic (blue one not the yellow project) but can't place it
Originally posted by rallyreturn View PostKevin Hill, rallied that blue Escort in the 80's with my brother David co-driving, mainly in Wales but you might know it from when I sold it as it's been around for a few years and is now owned but a chap in Crosshands West Wales.
Mark Hedges
Just removed the front end.
Needs repair to inner wing where the battery bracket has been removed and the past accident damage on top of the wing needs to be cut out and replaced.
haven't even bought a mig welder yet!!!!!!!
Doesn't look as though anybody is interested in my build but I'll carry on anyway. LOL
Cut out the horrible firewall and stripped off all the paint and discovered both wells have patches so I'll cut them out and butt weld new patches.
Started on the passenger side splash panel and wing rail, lot of fabrication to do here and a few patch repairs.
Not much more done but I'm going to a Family Wedding next Month in Vegas and making it our 2 week holiday so funds are tight at the moment, but as soon as we get back I'll be able to buy a mig welder, compressor and rollover jig and really get going at it.
