local engineering places, machine shops keep them G
The Black Beauty
 they are the ones supplied with the mimilite wheels Bri, all i have done is add the RS centre logo, they fit the centre from "inside" the wheel thus cannot be prised off / nickedOriginally posted by Banishit View PostG those boot pics look great mate, what are the chrome wheel centre caps from ? MK1's
 will post a pic or two later
 cheeRSsigpic
 Originally posted by Lord Lucan View PostGraham where did you get the Carbon Door Cards from as I will be after a set of these for mine in the near future
 JMC in Barry, south wales, will post them to you.
 tel 01446 737222 or www.jmcmotorsport.co.uk
 they look very nice too !
 cheeRSsigpic
 need to now fit the centre console up to the new switchpanel gonna have to get the Dremmel out im afraid
 wish me luck !!!
 if i dont finish this thread you will know i made a balls up
 cheeRSLast edited by graham John; 14-10-2007, 17:59.sigpic
 made the bold move and attacked it with the dremmel
 then marked out the switch positions as i want to keep the original ones but have to relocate them into the console as the (new) switchpanel now accomodates the cut out, starter buttons, fire extinguisher etc etc
 then tried a 'Dry' fit, needs to trim the edge a little to get it closer and then raise it slightly to meet the mounting holes,
 once trimmed, will give it all a good clean and re fit
 cheeRSLast edited by graham John; 15-10-2007, 12:55.sigpic
 Why don't you use a piece of cardboard to copy the rounded V-form of the upper console bit (with the masterswitch and starterbutton in it)?Originally posted by graham John View Postthen tried a 'Dry' fit, needs to trim the edge a little to get it closer and then raise it slightly to meet the mounting holes,
 You then place the shaped cardboard bit on the lower console and dremel the V-section away.
 If you know what I mean ...
 Originally posted by Miniliteman View PostWhy don't you use a piece of cardboard to copy the rounded V-form of the upper console bit (with the masterswitch and starterbutton in it)?
 what i actually done was to make a cardboard console (will put it on ebay later ) and tried it for fit, then cut the sections away, however it was not an exact science but got me more or less to where i needed to be ref marking and cutting, ) and tried it for fit, then cut the sections away, however it was not an exact science but got me more or less to where i needed to be ref marking and cutting,
 finished product looks good, more pics later
 cheeRSsigpic
 Originally posted by Skids View PostLooking good GJ
 Rallying in luxury,carpets,heater,heated window all items sadly missing from my scrapper.
 Keep the pics comeing as it gives me some good ideas to copy
 Mark
 yes, the plan is to make it comfortable inside and also retaining as much standard stuff to keep it period and functional, from the outside the car will look very standard, however those in the know............
 cheeRSsigpic
