Mk1gaz's new engine build
  • Awesome progress Gaz - coming to a street near you soon.....
    Thx for info on rolling road - hope to have engine ready in next few weeks and will try one out - somewhat doubt it'll give them as much entertainment as yours!
    Laurie
    • Cheers Laurie
      • Originally posted by mk1gaz View Post
        Three cheers for Steve at Vulcan as he's made me some bolt in alloy core plugs today . I can fit these without taking the engine out and drilling the block . Top stuff .
        a right result Gaz
        • Here's a pic of the new bolt in core plugs with a standard one next to them . Pretty posh really , cheers steve
          • They look cooler than the type with 3 cap heads around em
            You need sealer i take it?
            Is it a water pressure problem doing it do ya recon?
            • Originally posted by bortaf View Post
              You run a bead of silcone around the hole in the block and also under the washer for the securing bolt . Then just bolt them in the hole and they can't ever fly out . Apparantly some N/A engines produce a shock wave when they make lots of power . As the core plugs are next to the cylinder bores this shock wave goes through the water jacket and blows the core plugs straight out of the block .
              • Tonights progress . All done and ready to rumble (again)
                • The weather is so bad at present that i can't get anywhere near 8000+revs to test out the new core plugs . Anything over 5000 revs is bordering on the dangerous as the roads are proper soaked and the arse end is comming out in 3 gears !!!!!! Great fun though
                  • We've run the engine on the dyno this morning quickly before the shop opened so we only had 3/4 of an hour to play until the customers started turning up . We had time to sort the full throttle fueling but had to leave the rest of the mapping and the cam swinging until another day . Looking good so far though with 222bhp and 173 ibls/ft of torque . Most importantly i now have an extra 26bhp and 14 ibls/ft at 7200+ revs all the way to the limiter . It goes like fooooook . Graphs and videos later after the football
                    • sigpic 2.1 ATMO YB POWER .
                      • dave walker was writing about the core plug issue in CCC 20 yrs ago ! if i rememember your collection correctly then i reckon you might have the mag gaz
                        ps. glad its running again, shame its got no power adders tho on that std pinto.
                        • Here's a graph of the new engine spec verses the old one . Note the extra 25bhp at the top end although the "peak" figuire is only 6bhp more than the old 215bhp engine . This is also on the same Dyno-Dynamics dyno (bhp thief) where my 250+bhp 3.5 litre BMW Alpina made 220bhp (so 222 is pretty good with 4 cylinders , pump fuel and 1.5 litres less)
                          • Turn up your speakers
                            • Woohoo!
                              nice 1 Gaz, music to my ears!
                              rock on mate
                                All that's needed.
