Restoration op Zebra
This topic is closed.
  • stop being a nob and get it sorted
    • Originally posted by RS2kSX View Post
      now thats awsome not noticed that bit of wood in my haynes manual
      • The wiring isn't that scary Andy, most of it is multiplugs anyway. A good auto spark ( or bomb disposal expert ) will get it sorted no bother.
        Alternatively, a good look at someone elses car (the more stripped out the better) and work out where the bits all go.
        Very seldom is a wiring fault in the middle of a bit of wire, if somehing is wrong with it, it will be a component, a bad joint, or, the harness chaffed through. You can rule out the last one before you fit the loom, so , that doesn't leave much to be wrong with it. Connect it up and see what happens.
        • "Simples"
          • thanks matey
            • Originally posted by grum View Post
              "Simples"
              So which one caused all the damage to yours then..........
              • the one he messed with
                • Best advice is junk any alarms/etc then use the manual ,all wires are colour coded on the drawings ,IIrc the only thing not shown is the inners (lights)which should be obvious.
                  Just keep an hose handy
                  CheeRS Neil
                  • im going to do that asap
                    • And don,t forget Andy Red to Red , Black to Black and blue to smithereens
                      • Originally posted by 68 Bullit View Post
                        did you know he was in the bomb disposal squad
                        andy C and enduro working on the Electrickery parts of the car as we speak,
                        where's the pics Andy ?
                        • classic
                          • quality
                            • just had a call all is going to plan!!!!!!!!!!
                              • photos later chappies
