Hey Robert, nice to finally get stuck into her, u have a fine warm looking shed for the winters work! All the best with the resto, gimme a buzz if ur stuck for bits. Stephen
Thanks Stephen, yes, I have a radiator in there too so its not hard to work in. its small, space is scarce and expensive in Dublin!! will be in touch.
How is yours coming on.?
Robert
Its not too bad now, slowly going back together, waiting for a few engine bit so I can fire her up, and must finish off the seat with the covers from Alridge trim, hard to go into the shed on these winter nights!
took the front end off. Have the new inners and bulkhead ready to weld in. Did a test fit and lined up perfectly. had taken a lot of measurements and the new one fits mm perfect. (thanks Darran) I split the a pillars and will spot back as original. Using my own dash,& heater bubble. I used the 'scaffolding' to line up the door restraint eyes and relocate the new front.
dit a bit of patch work on the tunnel before doing the floors.
