My RS 2000
  • #16
    Getting on fast
    Good luck,great work so far
    • #17
      Like the jig, nice one
      CheeRS
      Martin
      • #18
        Wow thats a posh floor
        • #19
          My RS 2000
          Hey Robert, nice to finally get stuck into her, u have a fine warm looking shed for the winters work! All the best with the resto, gimme a buzz if ur stuck for bits. Stephen
          • #20
            Hi Robert,
            Best of luck with the restoration.
            Errol
            • #21
              Nice looking jig
              Your well on already keep the pics coming
              • #22
                Thanks Stephen, yes, I have a radiator in there too so its not hard to work in. its small, space is scarce and expensive in Dublin!! will be in touch.
                How is yours coming on.?
                Robert
                • #23
                  Originally posted by andym View Post
                  You have a good base to work from, All the best.
                  Thanks Andy,
                  I been watching your progress, and taking notes, it's great to see how others are doing whats ahead of me....
                  Robert
                  • #24
                    My RS 2000
                    Robert
                    Its not too bad now, slowly going back together, waiting for a few engine bit so I can fire her up, and must finish off the seat with the covers from Alridge trim, hard to go into the shed on these winter nights!
                    • #25
                      cutting started.....
                      took the front end off. Have the new inners and bulkhead ready to weld in. Did a test fit and lined up perfectly. had taken a lot of measurements and the new one fits mm perfect. (thanks Darran) I split the a pillars and will spot back as original. Using my own dash,& heater bubble. I used the 'scaffolding' to line up the door restraint eyes and relocate the new front.
                      dit a bit of patch work on the tunnel before doing the floors.
                      Robert
                      • #26
                        thats some amount of work your putting in there hope it all works in ok
                        • #27
                          nice one mate, dont loose faith, keep at it, its well worth it in the end!
                          • #28
                            wow, makes these two look like beginers, awsome work YOU HAVE BIG GONARDS
                            • #29
                              **** me
                              That's some work going on there,keep it up
                              • #30
                                hi looks like you have lots of work ahead of you,are you doing it all yourself best of luck.
                                Mk2 Escort Harrier white
