MK1 RS1600 Service shell Rebuild
  • #91
    Got a bashed lip jobbie here if you want some pics
    • #92
      Originally posted by Charlie Chisholm View Post
      Front end really rusty mark , both rear quarters and boot floor will survive ha
      Lower bulkhead , was far better than top, only set back was on o/s flitch (Where it join's on door post was 20mm short) Post a pic up later , had to joggle and fit piece in , did have me worried for a bit tho. Nice gauge steel 1mm thick , lots of holes to drill for pedal box etc but i will get there, eventually . Might need a favour of you mark, need a few pics of the cut out on the bulk head for the bda engine, original was patched up bad plus it was running twink lump in later years. Have you got any (without engine fitted mate )??? If so any chance you could mail them to me please
      Here you go Charlie.....
      I have full size versions of the above plus shots from inside the car.
      Also pics of the upper bulkhead where the throttle & speedo cable fit.
      Mark....
      • #93
        Top man cheers !!
        Did not think cut out was as deep
        My email is charlie.chisholm1@btinternet.com Please forward pics mark as they will be a great help mate
        PS Nice proper bda shell mate in pics
        Regards Charlie
        CWC Restorations
        Boldon Colliery Industrial Estate
        Sunderland
        M 07984 888010
        L 0191 4478201
        cwcrestorations@btinternet.com
        • #94
          Been a while so here are a few more pics
          Decided to repair door posts before i fully welded up lower and upper bulkhead .
          Needed to brace innerposts in place before i could get ruddys grinder out.
          Just a bit of box section welded between inner posts and secured to transmission tunnel.
          Door fit was good on n/s before i started so it was very importand i kept positon of inner door post spot on.
          N/S Door post with door removed , does not look horrid but it was full of rot. These rust in amazin fashion on mk1 and 2's
          Regards Charlie
          CWC Restorations
          Sunderland
          M 07984 888010
          L 0191 4478201
          • #95
            awesome job charlie, keep pics coming!
            • #96
              Thats exactly whta I have to do the A posts, and wondered where to start
              • #97
                top work Charlie, gonna be a mega car
                • #98
                  As said,top work charlie,well done
                  • #99
                    rs1600
                    Hi charlie, keep up the good work mate!
                    AVO Club Spares Officer
                    • A few more pics
                      Now inner post is secure the outer could be removed without to much worry about moving about and losing alignment of door
                      I used Hadrian outer repair skins, used them before and happy with fit.
                      Starting to remove outer skin
                      a bit more
                      next picture shows outer skin fully removed , i then set about cutting out rot and welding up too make sound. The inner post , the bit left is not serviced by anyone so same has to be repaired or swapped for a good 2nd hand one. Was lucky i manged to save
                      Inner post fully repaired and ready to fit new outer
                      New outer in position prior to welding up
                      Regards Charlie
                      CWC Restorations
                      Sunderland
                      M 07984 888010
                      L 0191 4478201
                      • looking great
                        just out of interest, how do you come by the panels ? are they fairly easy to get hold of still ? or do you have to spend mega money after finding them ?
                        • Hung door to check alignment before i fully welded up
                          Lower bulkhead welded to new door post
                          Tis nice to feel like you have made progress ha , next o/s post and its rough
                          Regards Charlie
                          CWC Restorations
                          Sunderland
                          M 07984 888010
                          L 0191 4478201
                          • Originally posted by grum View Post
                            looking great
                            Door post readly available from motor factors
                            Bulkheads etc from ex pressed and very expensive
                            Still a few genuine panels about but getting a tad expensive
                            Owner of bda has spend a few years searching for panals before getting car restored mate
                            Regards Charlie
                            CWC Restorations
                            Sunderland
                            M 07984 888010
                            L 0191 4478201
                            • great work charlie, very clever stuff going on there
                              • excellent work their clutch cable who's next for a resto ???? you could easily do this professionally just on the escort's m8 with a little from your m8 hadrian
                                keep em coming m8
