have u bleed the boiler???
Heating system
I had the same thing this week on 1x rad and my mate just turned the supply valve thingy on the rad back and forth and this fixed it .
had this bother myself on a couple of rads took them of and ran water through them from the garden hose unreal how much sludge comes out them but on taken them of found a few of them had the vales shut back a bit fully opened the ones furthest from the boiler and turn the rest back according to the position of the pipe run
keep it as long as possible, as most new condensing type boilers will not last any where near as long.just try turning off all the hot ones. then the cold ones should get hot. sometimes the valve gates can get stuck or come off their spindle.if they still dont get hot take the cold rads off and flush them through with hose pipe. then you can also check the connections (flow and return) of the pipework to each rad.attach a hose pipe see if water comes out.or catch it in a bucket.just a few cheaper ideas.Originally posted by ModenaRS2 View PostIts a Gloworm Ultimate, it was serviced about two months ago.sigpic
Originally posted by richy c View Postkeep it as long as possible, as most new condensing type boilers will not last any where near as long.just try turning off all the hot ones. then the cold ones should get hot. sometimes the valve gates can get stuck or come off their spindle.if they still dont get hot take the cold rads off and flush them through with hose pipe. then you can also check the connections (flow and return) of the pipework to each rad.attach a hose pipe see if water comes out.or catch it in a bucket.just a few cheaper ideas.
Going to try this and other suggestions. I am reluctant to take a rad off as we have new carpets and the last time I took one off I made a right mess
She will kill me if I make a mess.
If it does not work then I will get the proffessionals in (not Bodie and Doyle)
Many thanks for all the advice.
After a month of cold and two plumbers it is still not working properly.
I also dumped a load of black sludge on thew new carpet
I want to put a good chemical in to see if there is sludge floating around. Can anyone suggest some thatI can get from Plumb centre or Plumb base etc.
Also how do I get it into the system?
Cheers in advance.
if it is sludged up,ie lots of black sh#te you can hire the flushing pump, normally from most plumbing suppliers.connect to where the pump. is block of open vent and cold feed, then do each rad separately. the place where you hire it from would also advise you on chemicals, procedures etc.
I power flushed my mates system at the weekend, 11 radiators and took about six hours. I used Fernox but Sentinel is better in my opinion. This will cure your system of all sludge, however if you have any dodgy connections this will expose them ! Go to a Travis Perkins hire centre for the machine its about £60 for the weekend plus cleaner and inhibitor.
says Cpt. Flood
