Arch rolling
    Arch roller here will be doing mine at the weekend so will keep you all posted
      you got a contact phone number as i want my fronts doing
        PM sent.
          One of my Mk1's has just had new rear arches fitted. Could really use your services!!!
          PM on it's way
            Be careful with the heat gun. Those things are lethal. The dent man uses one when straightening panels and he just flicks it over the paint. If you hold in one place for long you will definitely blister the paint.
              Rolled a couple of arches so far and turn out well.All i will say is if the paint has any rust or paint scabs it will crack the paint and flake off heat or no heat.If the paint around the arches is good they will roll no probs with no paint cracking,I used a heat gun with no probs ,it quite a slow job and you have to really take your time ,bit by bit..
