200 4x4 Cozzy block
94mm Accralite Forged Ally pistons
4x4 Cozzy crank - knife edged, balanced and lightened, 76.95mm stroke
4x4 Cozzy Rods - Oil squirt hole drilled in and new little ends, ARP rod bolts
Lightweight 9 hole flywheel ARP bolts
7 1/4" AP racing multi plate clutch
Burtons HP/HC oil pump
Twin weber 45's
Kent RL31 Cam - X drilled and no spray bar
Roller rockers
Head being prepared by Cylinder Head Developments - Bromsgrove
(spec and pics when complete)
Large bore multi piece exhaust manifold and large bore gaskets
Large bore inlet manifold and gasket
Ignitor Ignition
Will all be set-up on Hitech rolling road, Cradley Heath
Twin weber 45's
Roller rockers
Ignitor Ignition
