Sorry, I do not work for Diesel Engineering.
Glyn does.
I work for Gasoline (Sorry Petrol, I work for a American company and they do not recongnise the word petrol) Engineering on all the Duratec engines.
So I do not know much about the Diesel engine families.
I do know all the modern Ford Diesels are a joint venture with Citroen / Peugeot and the 2.0l is a real stormer.
These engines mate to Ford gearbox bellhosings.
Glyn does.
John
Apologies John, I thought Glyn and yourself worked for the same team
If they are a joint venture with Peugeot/Citroen are they based on a HDi?? Or do they just use the fuelling system??
Being a Duratec calibration development engineer, I do not know the terminology for the diesel fuel injection systems.
I do know that all current Ford / PSA Duratorq diesels are high pressure direct injection, common rail.
not as tuneable as the 130 im afraid geez, spose if your never going to touch it then youd never see the difference.
Had good results with mine. Upsolute re-map to rolling road proven 204bhp with 440Nm of torque, a K&N panel filter and that's it The 150 has a bigger intercooler as opposed to the 130 for a start. The rest of the engine is almost identical to the 130 apart from a few changes here and there.
