My Mk1 Escort 1300 Sport Project
 Only one thing for it, I've had to buy a complete inner tub from ex-pressed panels....
 which has meant un-doing my previous tub repair in the tank well area. I've removed the rear tub, found more of the famous woodgrain steel patch repairs tacked on & covered in black sealer
 tub removed
 inner & outer sill full of filler, glassfibre & rust!
 Hi all, next job is to sort the floors out, its had floorpans put in in the past, but they've been welded over the seat boxes & mounting holes, inner sills have been plated over, also the floorpans haven't been welded onto the chassis rails, the gap has just been filled with black sealer.
 Firstly I've bought a load of box section steel & welded in a frame to keep everything rigid before I start cutting out the floors.
 Gone a bit overboard with the frame but want to make sure nothing twists or moves
 Hey now that is what I call a proper roll cage!Originally posted by mk1GTstu View PostHi all, next job is to sort the floors out, its had floorpans put in in the past, but they've been welded over the seat boxes & mounting holes, inner sills have been plated over, also the floorpans haven't been welded onto the chassis rails, the gap has just been filled with black sealer.
 Great job nothing should move there while your working on the floor....best to go overboard a little than have something twist! Those rear arches are looking really good too!
 Tim
 Originally posted by RS2000EXPRESS View PostHey now that is what I call a proper roll cage!
 Tim cheers! yeh I'm pleased with my rollcage, might leave it in cheers! yeh I'm pleased with my rollcage, might leave it in
