This next job was the last piece of welding on the front of the car so now its done im quite chuffed to say 1/3 and a bit done and just under 2/3 to go
Once the N/S floor is in I can then get it up on the spit to sort the rest of the horrors out.
This job will need finishing once its up on the spit as its a cow working over the wheel and around the antiroll bar etc so once they are removed and im not crawling around on my knees I can give it some closer attention.
This was this evenings job
Started cutting out the rot and it seemed to just continue, plus it had a repair here in the past
Made up this repair plate for it
Drilled the holes in it for the antiroll bar mounting bolts and trimmed it a little bit more
Welded into position
Quick clean up and a lick of paint until I get it up off the ground and give myself better access
