Originally posted by Brammer
my first mk2
No more progress yet tony, Got the keys for the new house on wednesday evening so all systems go there and escort on the back burner for next month or so probably, so far had to change the consumer unit, rip out and replace the kitchen ceiling, rewire all the bt lines, re wire all the tv cables, partially rewire the downstairs socket circuit, decorate the living room and 3 bedrooms and re plumb the kitchen.............needless to say im pretty tired and just to ad to the list need to get all the floor boards back down tomorrow fit carpets and move out the old house and into the new house before thursday and both Faye and I are unable to take any time off work next week!!!!!Originally posted by HarrierTony View PostHow are you getting on with the floor Jon ?
Il be desperate to get back in that unit and start welding again you believe me.......lakes tour 2025 springs to mind lol
The spit works spot on pete. Would be nice to see one of marks cars on the road again hes had them 15yrs + I believe. Saying that he threatened to get one done when we were doing my black series 2 about 4year ago lol....Mark get ya welder out ffs lol
Fair coming on - well done
Got sick of housework tonight so had a couple of hours on the car so chopped the old bootfloor out, took some measurements first and welded a brace across the end of the legs. Managed to get everything set up to weld the new bootfloor in place. Have some pics on phone but have no Internet connection in the house yet to upload them. Hopefully more updates soon. If any mods can help with uploading my pics I can email them. Thanks Jon
Spent an hour bare metalling the bootfloor so it can have a light shot blast before fitting
Going to finish bare metalling all the inside of the quarters and underneath the parcel shelf before fitting, hopefully get a day on it over the weekend
Just going through this excellent thread and read the comment below (probably again) re seam welding.
I'm pretty sure the MOT rules say that as the car has unitary construction, i.e. body = chassis, all panels that are attached (excluding the front wings) and repairs to them must be either welded as at the factory, i.e. whole panels spot welded in, or, panel sections or patches must be mig welded in place with a continuous seam of weld (no-gaps).
You are not permitted to use oxy-acetyline etc as this weakens the steel, because too much heat is applied. That is most certainly what I learnt at technical college nearly 25 years ago now...
Originally posted by 13sport View Post
Trying to decide if i should seam weld the front floor pan to the inner sill as you can see in the pics its Spot welded together, its strong enough so might just seam seal it yet
Didn't get the bootfloor or the rear panel back from the boasters this weekend so made some more progress getting rid of the rest of the yellow dulux. Stripped inside of rear quarters and under parcel shelf. Decided to blend in the arch repairs on the insides of the quarters with this green fine fibre glass filler it's really good and sands down just like normal filler
Them spent a couple of hours bare metalling the quarters and the roof with 80 grit on the DA and gave them a coat of etch as I didn't want to blast them
And the top side
This actually feels like good progress even tho there's no filler work done 3 Area off the shell ticked off the list
Got the bootfloor and rear panel back from the blasters this evening. Managed to get a coat of etch on them and tach the bootfloor in position ready to fully weld hopefully fri night/Saturday. Rear panel sat in position to check everything fit ok.
With a bit of luck that should be the bare shell all welded up for the weekend then blasted and etch primes in the next couple of weeks if funds allow, il be glad when it's done then its just outer panels to work on, one door nearly done and the other to do. Might even be ready for next winter lol
