Hi all had a mk1 which was my first bought about 6 months ago, it needed a lot of work and i got a good offer on it so ended up selling it and knew about this x pack mk2 so went to see it.
It was difficult to see how good or bad it was or good it was due to it being used as a storage space all i could see is that it was caked in underseal.
first thing to do was to remove the x pack as personally it didnt float my boat. Couldnt believe how good the quarters were behind it, only a couple of screw holes as the kit was mostly fitted using resin. Hopeing to save them and convert back to standard using a door skin and arch repair, have some mint tubs cut out a shell already.
at the worst way il tub it again and tarmac arch it
Anyway being keen and only having owned it since 2pm yesterday i thought id start at the front and work my way back. the inner wingsd were full of filler as someone had started to smooth it forgot to get a before pic but after removing it they are pretty good, it had 2 strut top repairs panels poorly attached with snotty weld so i removed them to find one mint strut top and one strut top with a small patch of swelling but numbers still there and correct to v5
