Top job Andrew. Be careful though as If you show people how good your welding is, You'll be innundated with requests....
Jaffa's Return
Well spotted! The captive nuts are for a removable battery tray - makes initial painting and then cleaning and checks after acid spills easier. The captive nuts are bona-fide Tornado titanium bits!
There are a couple of extra holes for P-clips to retain cable looms and runs on the engine bay side. To be honest, I put them in when the bendy metal strips snapped off and was considering welding on new bendy metal tags but, as the car will never be concours / bufty I thought I'd stick with bolted on P-clips.
Fitted them in 1985 Lee. Still waiting........ LOL!Originally posted by lee bishoptitanium against steel, expect some dissimilar metal corrosion anytime soon then, lucky you can unbolt your battery tray and check up at the rate of its progress
