He is doing a great job....well chuffed with how its coming along
MY MK2 RS2000 Resto and XPack Conversion
 got a bit more done this week just not had time to put photos up
 passenger side inner and outer sill
 wings and landing panel fitted
 nose cone trial fitted again
 front crossmember made into rs one
 front panel fitted
 wings cut back for the x pack for maximum clearance
 one rear tub half done just to solid weld the inner arch up then trim to size
 hopefully get the other side done tomorrow and the fit the x pack
 71/2" replica alloys Ł90 each midland wheels (has to be done) Johnie
 Andy
 as said on rwd...looks the buisness mate
 got some more done but dont look much as it is all the fiddely stuff on the drivers side and round the nose cone
 back on its wheels loads of clearance (better get some 2" lowering blocks)
 front panel on drivers side ground and primed
 x pack on the drivers side now bonded and riveted to the car (with 3 times as many as was holding it to the car it came off)
 redone the nose cone ends as they were flushed in at the bumper rather than sitting over like they should also fitted them to the cone so they dont need so much filler
 also primed and sealed the inner arch inside the boot
 dont look like a lot of work but nose cone ends took nearly 2hrs to do alone to get them anywhere near right before they are fitted, probably another 2 days work to finish the drivers side ready for primer
 get some more done tomorrow
 Andy
 malky you better start saving mate
