MY MK2 RS2000 Resto and XPack Conversion
  • #31
    Originally posted by andyg View Post
    will get yours back once you get all your bits got some photos of yours but they are spread over two phones
    back to Malcoms for now
    got the top of the bulkhead sorted will get under the bonnet hinge done when the inner wing comes back of
    got the other inner wing on and front crossmember just need to sort the bulkhead on the n/s once done will fit the rest of the panels line it all up then remove clean up etc and finally weld it all in place
    more tomorrow
    Andy
    I'm sure Malcom will like it once its finished.
    SIDEWAYS THE ONLY WAY
    Vicky.G
    • #32
      Nice work
      • #33
        got some more done today
        got most of the front on and lined up just selfdrill screwed on for now but will come of and go back on in the same place
        had a problem with the gap at the nose cone so fitted my own one and it's the same
        had the same problem on my last car as well measured the wing and it is 6mm longer to the fold for the nose cone so will have to unstich it and re fold it
        thats for next week
        Andy
        • #34
          excellant andy top notch work.did you get a new lower rad panel and did you make the rad cut out yourself because i notced it was botched before
          • #35
            ye got a new front crossmember for it just a standard one but have the templates for the cut out some dodgey welding on it most of the repairs come of with a pull from a pair of vice grips, the n/s centre chassie section was not even welded to the new floor pan!!!!!!!
            Andy
            • #36
              Great work Andy, some progress in such a short time.
              • #37
                got the wing unstiched tonight and refolded in the right place then welded back together now the gap is the same everthing can come back off and get cleaned zinc primed and then welded
                Andy
                • #38
                  does'nt take long when you are fitting whole new panels just takes ages when you have to make templates and cut out patches of rust and weld them in again
                  Andy
                  • #39
                    nice andy you used to make rs2000 wings if i remember right
                    • #40
                      Ha ha well he made up the ones on mine!
                      It's bad when I'm a panel beater and he's a joiner
                      Making a cracking job as per usual
                      www.scottisholdskoolescorts.co.uk
                      bbs.highlandoldskoolfords.co.uk
                      • #41
                        Originally posted by BJ View Post
                        hi mate a mate of mine is selling one
                        Hello mate any luck getting a price and some photos. Sent a couple of PMs not sure if you got them.
                        • #42
                          got a bit more done last week
                          got the wings etc back off and repaired the bulkhead under the bonnet hinge
                          and got the inner wing tacked on won't weld fully till it's all checked again
                          n/s bulkhead repair just got the kick panel to do when I do the inner sill (pulled the patches off with a pair of vice grips)
                          also got the top plate and support welded on the standard inner wing
                          • #43
                            comeing on well there m8
                            keep it up.
                            dav
                            • #44
                              top work as always andy boy!
                              • #45
                                got some more done over the last 2 days
                                all the unwanted holes in the bootlid 23 in total
                                sorted the strenghners at the bottom of the turrets as they had a bit missing
                                started the patch for the bulkhead just got it to weld on once the inner bit is repaired
                                sitting in place
                                Paddys also got the roof back to the metal and primed the doors and boot are done to but forgot to get photos of them
                                Andy
