also front headlights (Dipped) stopped working for some reason
Rotate the fuse (3 IIrc) a few times to clean up connection and lights should return ,ask Taffr, fixed his couple of weeks ago. If your still using the std fuse box for these lights ? If you are may be worth removing fusebox and giving a good clean with soft wire brush and clean ends of fuses with wet & dry.
top tip this, cheers neil, good work GJ, can't wait to see it thrashed on the mountain
