is it working yet ?
The Black Beauty
 got myself a new 'Spare ' redtop fuel pump and took the old one off (was working intermittently), so now have two new ones, little bit of re wiring and on / off with the Aeroquip and looks nice now.
 series X latches to finish fitting, also front headlights (Dipped) stopped working for some reason, then book it in for an MOT
 cheeRSsigpic
 Rotate the fuse (3 IIrc) a few times to clean up connection and lights should return ,ask Taffr, fixed his couple of weeks ago. If your still using the std fuse box for these lights ? If you are may be worth removing fusebox and giving a good clean with soft wire brush and clean ends of fuses with wet & dry.CheeRS Neil
						 to be F**ked by kittens
