The Black Beauty
 :knob: Apologies GJ I didn't realise you had been posting this afternoon,when I looked this morning you hadn't replied (see you've had the computer gremlins in ).
 Another lesson read before you write
 Keep sending the pics.
 PS Where do you buy your parts (Rally Prep) from ?sigpic
 AgreedOriginally posted by graham John View Postyes, nose cone is staying, i love the appearanc of it and i take the view that if i do 'stuff it' then i will be a little further back from the accident with the nose cone on
 all seam welding done by myself and now virtually completed (phew)
 will keep the pics coming, keep the encouragement coming as well lads
 cheeRS keep the nosecone.... keep the nosecone....
  Mark.... Mark....
 no prob's i guessed youd missed the postOriginally posted by Skids View Post:knob: Apologies GJ I didn't realise you had been posting this afternoon,when I looked this morning you hadn't replied (see you've had the computer gremlins in ).
 yes, computer probs are severely hampering my updates on the ole girl.
 Ref parts, mainly Peter Lloyd Rallying (Bridgend) and JMC (Barry) in south wales, both good service in my opinion, and both give excellent rates particularly on a long term build.
 of to autosport for some bits next week, alloy rads , and also silly things like Grommets (not the Wallace type ) cables and hoses. ) cables and hoses.
 Warning: Rallying can seriously damage your wealth
 stay tuned,
 cheeRSsigpic
 spent most of the weekend cleaning the engine bay, was a right mess - full of dust and crap from the bodyshop, literally took four hours to get it looking decent.
 anyway, having had chance to survey the engine bay (now clean and clear of debris) it's time to evaluate what goes where, in what order and what needs doing prior to starting putting things back together.
 first thing i had to do was establish whether to leave the original cross member fixing studs or go the "through chasis rails" route.
 The original fixings were, surprisingle, very secure, and have never given me a problem in the past, however as i was using a new Group 4 type WCXM then i have decided to go through the chasis rails.
 will post some pics of work in progress
 cheeRSsigpic
 Originally posted by graham John View Postspent most of the weekend cleaning the engine bay, was a right mess - full of dust and crap from the bodyshop, literally took four hours to get it looking decent.
 anyway, onwards and upwards,
 i took a lot of detail measurements of the bolt holes as i wanted this 'spot on' and not risk being a few mm out, as this would effect things further down the job, therefore with it all stripped, marked, checked, re measured and checked again, out came the Drill bit
 note rusty bit on inner wing .....
 then out with the bigger Bit, best to use a slow speed on the drill for this bit, nice n steady....
 and double check with right angle / square
 Drill out (from the bottom) the threaded section of existing captive thread in chasis, be carefull here as the 'thread' will unwind like wire and 'wind out' - quite dangerous and very sharp. make sure drill is 'square' at all times - i checked every few seconds - and hopefully the bottom holes will line up with the newly drilled top ones!!!!
 lets hope so
  if not.................... if not....................
 cheeRSsigpic
 I simply drilled up through the captive nuts and held the drill verticalOriginally posted by graham John View Post
 Perfik Last edited by RS2000CUSTOM; 09-01-2007, 18:59. Last edited by RS2000CUSTOM; 09-01-2007, 18:59.
