2 New Engine Build Projects
    First "dummy" build to measure how much to be removed from the pistons
      How does that device work then Dave out of curiosity.?
      Naturally Aspirated Power
      RSOC Member
        By the look of it you place the gauge on the block set it and then place on the piston and the difference in height is what needs to come off
          look forward to seeing these get built...both great classic oldskool engines
            "dummy" build ... is that because you are doing the work??
              Correct andy
              Zero the dial gauge on the frashly skimmed block (only skim enough to make it "flat")
              Put gauge over the bore and bring piston to TDC
              The "extra" is how much the pistons require removing off the crown to bring them flush with block
              Will do more pics along the way
                Finally been able yesterday and today to comandeer the lathe and milling machine at my friends engineering firm (cheers Doug at DJL Engineering)
                With Dougs help (well he did all of the lathe work and set-up the milling machine for me - lol) the pistons are machined and the conrods have an "oil squirt" hole machined into them
                Note:- Cozzy 4x4 rods do not have the oil hole in them as the 4x4 Cozzy has a seperate oil squirt rail to lube and cool the pistons in the bore.
                Without this hole the little ends and bores would suffer oil starvation and not last very long
                Doug machined some "soft jaws" in the lathe to accept the pistons to ensure no damage or markings on the pistons body when being held whilst turning them down
                Then all 4 pistons weight checked to retain correct balance.
                Con rods then set-up on milling machine to pick-up on bearing oil feed hole and angle up to the piston/bore
                Then again all 4 con rods are weight checked
                All ready now to begin putting Cossie Si's Pinto together (at last)
                More pics along the way
                  Well thats 1 engine finished, fitted into car and back with owner - Cossie Si
                  I dont think Cossie Si has worked so hard for a long time
                  Got to mine on Thursday night
                  Worked all day Friday - had lunch at The Vine Indian Pub in West Brom
                  Friday nite out in Cannock
                  Si walked round Saturday like a zombie - lol - Then we had Tea (evening meal) at Sukis Indian restaurant
                  Today got all the jobs done on his car and Si on his way at 19:00 hrs
                  Car sounds and goes very well
                  I took it for a road test near my unit and car got called a Red Capri - lol
                    interesting build thread dave, engine looks well also
                      looking very nice
                      AKA The Dipstick
                        Si's car started without any jump leads and no sparks or flames in sight - lol
                        • #27
                          result
                          • #28
                            i see you showed si some local night life engine looks well
                            • #29
                              You didn't say why i walked around like a zombie, 7 or 8 double g and t and vodka red bulls, in 3 hours, think i was stitched up!
                              Or why the car was seen as a red capri, good job the local plod don't know their cars and others out lookin were family, hey Dave
                              Not sure i could get used to eatin curries in the day though
                              Had another great weekend all round in wednesbury, many thanks again, think i need a week off now, not used to real graft lol
                              Hefty is the new slim!
                              Bald is the new bushy!
                              Muddy is defo the new shineeeey! (Copyright Grum 07)
                              48's are the new bike carbs !
                              • #30
                                nice work dave, makes me realise the extra stuff i could have done if i stayed as a tool maker after my apprenticeship
