My new Mex
4
Tim
17-08-2009, 22:24
good to see your continueing with the 1100 xl
jxe54
Apr 2009
17-08-2009, 22:29
Tim
jxe54
Apr 2009
24-08-2009, 19:28
Now at the blasters for paint removal with plastic media. Slightly harder stuff used for rusty bits. Guaranteed not to distort any panels I'm told...
jxe54
Apr 2009
18-09-2009, 21:44
Picked the shell up today. Perfect job.
Inside too, left the sound proofing as requested.
And found the VIN number too
Darran
Jun 2003
18-09-2009, 22:44
mk1
There very good
emily
Aug 2003
19-09-2009, 08:00
great stuff , coming along nicely
Groupfour
Jun 2007
27-09-2009, 18:03
That blasting has saved you so much time and hassle , looks very solid which is nice.
jxe54
Apr 2009
28-09-2009, 22:38
Engine bits back from Vulcan - build under way
Goodies
Pocketed 1300cc Pistons and crank. I hadn't realised the pistons come teflon coated for low friction like modern engines!
Inlet ports - head face drilled for matched manifold dowels. Vulcan recommends single springs until run-in to a void wiping the cam, then fit inners.
Block bored to 1700cc and wired, ready to go
Crank installed
Bottom end assembled with lots of lube. Cam installed. Set TDC with DTI, pointer on flywheel.
ARP Studs in
Timing in the cam
wetandwindy2
Apr 2006
28-09-2009, 22:54
nice coming on well now
andym
Nov 2005
29-09-2009, 01:37
Coming along now. Keep up the good work.
Andy
mike77cos
Feb 2006
05-10-2009, 13:15
Very very nice
mexicostids
May 2008
18-10-2009, 09:50
looks like a very good shell
keep the pics coming
jxe54
Apr 2009
26-10-2009, 22:31
Gearbox rebuild
Gearbox rebuild. General clean up, new bearings, seals, gaskets, reverse gear idler and first and second synchroniser rings and bronze top hat bush. Also some new layshaft needle rollers and layshaft which was totally crackered. Now perfect
jxe54
Apr 2009
26-10-2009, 22:33
Engine finished
Engine now finished. Needs a couple of bits and I have to drill and tap the front and rear of the rocker cover for breather unions.
Tim
26-10-2009, 22:41
looking good there mate
does that mean the shell is next on the job list
4
