Continued cutting, time for the sill to come off, the back end of the sill goes under the rear quarter near the bottom of the door so it also means removing the bottom of the rear quarter (it had a hole in it anyway), it also goes under and behind both the A post and B post, plenty of pics and measurements then grinder time !!
With most of the outer sill off I was very pleased with the condition of the inner sill/floorpan, the flanges were A1
Front end where sill passes under A post and meets side bulkhead and inner tub (new tub to be fitted)
Back end, rear quarter cut away and also bottom of B post
This is how it should all go back together , these are just laid on to give you the idea
Sill spotted on first, then bottom of B post
Then sill closing panel at rear
Then bottom of rear 1/4
Simples
, these are just laid on to give you the idea Sill spotted on first, then bottom of B post
Simples
 to be F**ked by kittens
