would a rs four spoke bolt straight to it?
Shifty's mk2 rs2000 rebuild!
I doubt it hally mate,Originally posted by hally View Postwould a rs four spoke bolt straight to it?
As you bolt the boss onto the colum and then screw in the 6 screws like on the wheel below....
which get screwed into these 6 tapped holes...
Hope this helps mate, as im sure the rs four spoke is just like a standard bolt on with the gig nut in the centre....
also if you look on the inside of the actual boss itself you will see the hole that it goes onto the splined shaft on the steering column, which that big nut that im talking about holds it on.
cool mate might well do then?
give them a bell and see what they say... http://www.cbradleymotorsport.co.uk/
if you want mate il measure the hole distance and let you know
Is yours like this underneath mate?
I never knew they had the 6holes...worth a try I suppose...
I dont know lol...I could measure the hole distances on the boss if you want mate. I dont have an rs 4 spoke to compare it tooOriginally posted by hally View Postthats the one mate does it fit?
...you could give them a bell and see what they say. Il do a wee diagram or something for ya tonight with some dimensions anyway
I put this paper on the face of it mate and punched through the holes...the tapped holes are roughly 3mm dia...hope this gives you an idea mate, just measure up your rs 4 see what you thinkOriginally posted by hally View Postsorry son i thought that 4 spoke in the pic was yours, yeah if you would do a diagram son?
The distances are from the hole centres....
Well then had the auld man to do a ''deal'' in a Kfc car park doon sooth today with a very kind gent who sorted us out with the gear we were after......
Heres what we got........
Thanks very much again Mr Frosticles
Cannot wait to hear them at full chat!
Good shift in again today lads....
Always a bit of a fiddily job this, but now its all sorted...seats really look the part in there now!
Next job is paint the whole cab again then run the wiring loom!...getting close!
lol
