I was thinking of seam welding my 79 rs2000 as per the rally prep book,i'm going to use the car for fast road & occasional track use and was wondering if this was O.T.T. The car is stripped to a shell at the moment for some welding,i'm just lookin for some opinions please
seam welding
A lot of it is seam brazing not seam welding - doesnt the Ford book make the point that welding can make it too brittle? Dont dismiss track as being an easier life for the shell. My rally car never used to loosen or split the rear firewall in the forests but always did when using racers on tarmac stages.
my fastroad/track car is seam welded but not fully i didnt do round the apertures but i did gusset and seamed the chassis rails does make a good strong shell for the track days mine has done 15+ and doesnt show signs of falling apart like some of the non seam welded cars that i have seen but ask any of the boys off here who i have took out ion my car and they will tell what i handles like :thumbleft: and the differance on the road is a solid feeling car that with the right suspension is a excellent fast 'A' road blaster
hope this helps m8
My shell was seem welded, best thing i did was the gusset the front.
Now i got a full cage welded in the strength is unreal....
Also a good point is the front chassis skids, add's quite a load of strength to a fairly weak point of the shell.
[/img]
