Never liked having my car on Axle Stands
  • Never liked having my car on Axle Stands
    So found a solution
    Nice one Martin, how much does that bit of kit cost, is it 3 phase supply?
    Gone to the Dark Side but still lurking!
      No it's single phase 240v 16A so you need a separate spur and the blue plug and socket as shown in the picture.
      Cost was £995 plus Vat
        Nice car
          i like the flooring too
          what i need is a high horse like the others have !
            Why do you have to lift your car up? Its not as if you know how to fix one ??
              VAT,,, the killer
                Nice lift Martin, one of them in my garage would make cleaning my Mexico easier
                RSmk11 club member no 61
                RSOC member no 17765
                  Thats a neat one Martin. Been thinking about one of these. Havent room for a 2 post lift.
                  Is it light enough to slide under a car from the side or wuold you have to drive over it? Also does it feel steady when raised?
                  Robert
                    Robert
                    It weights 300kg but the car drives over it so I leave it in position. It can be moved with 2 people if you want to slide it in from the side.
                    It is designed to lift 2700kg and is totally solid and sturdy when raised. There are safety mechanisms to stop it dropping down even if the oil pressure was lost.
                    It can go upto 1.5m high giving plenty of space to work on the car.
                      So I can take all 4 wheels off and removed the arch liners to clear out any dirt and debris that collects in there. Also so I can grease all the brake unions and check the rubber brake lines without having to lie on my back with unstable axle stands being the only thing between me and the car falling.
                      Does that answer your question
                        Better take it on your German trip mate
                          Originally posted by Lee R View Post
                          Nice car
                          Thanks
                          It's easy to keep clean and is click flooring so easy to lay
                          Originally posted by alancdavis View Post
                          VAT,,, the killer
                          Unless your Vat Registered
                          Why? We did 1500 miles last year with no issues except a puncture. That was 4 20+ year old cars and we weren't hanging around on the Autobahns
                            Well fingers crossed you don't need it , but take it anyway rather lie under a car than spend a night in Luxembourg ! !
                              martin , is the middle ram and safety thing with a locking type pin in it ?
