Originally posted by wetandwindy2
anti freeze
Originally posted by wetandwindy2 View Post
should you not have antifreeze in your system anyway as it helps to prevent corrosion in the system read that somewhere
Originally posted by RS2000CUSTOM View Post
correct sir
Well dont do it again till 2011 !Originally posted by wetandwindy2 View Post
 why thankyou kind sir nice to be right for a change its a yearly thing
On the pinto i just remove the fan belt and run the engine for a min or 2 then switch off and allow the heatsoak to defrost the block
Done it on many an occasion.
TBH i allways thought water expaneded when it froze? which is why if you fill a bottle all the way up and freeze it it splits ?
when you heat wateer it expands but not when cooling it back to a liquid ??
