anti freeze
rs new boy
anti freeze
24-12-2010, 22:12
anyone ever left there escort in the garage with no anti freeze
or am i the first dont want to look ,
69-johny-rs-07
Apr 2007
24-12-2010, 22:15
rs new boy
im using mine for a wedding monday went to start it yesterday guess wot i forgot
rs new boy
24-12-2010, 22:17
not you aswell
RS2000CUSTOM
5 Year+ Administrator
24-12-2010, 22:26
If engine is froze
Remove thermostat housing if poss to allow water/ice to expand as it thaws within engine or at least remove the bottom hose
If using heat to warm engine warm it up very slowly, hair dryer usually does the trick.
Dont forget to warm up the heater box as well before starting engine
Finished a Fiat Punto defrost yesterday using space heater blowing under car towards engine bay with bonnet propped open about 6 inches
Warm air flowed through the engine bay and I got away with no damage for the owner once engine started
Miniliteman
Oct 2003
24-12-2010, 22:31
Just checked; it's 16 degrees Celcius in the heated garage ...
rs new boy
24-12-2010, 22:33
RS2000CUSTOM
If engine is froze
dont want to look , not intending to start it i just need to know if it will be alright lack of interest in it caused it
RS2000CUSTOM
24-12-2010, 22:47
rs new boy
Its not the fact its froze that does the damage
Its when the ice thaws - if it has nowhere to expand it can at best pop out a core plug or worse crack the block
Remove bottom hose NOW ! Well maybe not right now if you havin a beer or 3 - lol
Chesney
24-12-2010, 22:51
rodders did
RS2000CUSTOM
24-12-2010, 22:54
Chesney
rodders did
rodders did what ?
Had a wash ?
Had a shave ?
What ?
rs new boy
24-12-2010, 22:57
RS2000CUSTOM
havin a beer at the min dave really need to sort this out so many things to do with my car, problems problems problems
Chesney
24-12-2010, 22:57
RS2000CUSTOM
rodders did what ?
Had a wash ? no chance
Had a shave ? not exactly, a slight trim but still looks a terwat
What ?
left his engine with no antifreeze, oh yes
25-12-2010, 00:20
just turned the garage thermostat down. Was tropical when I went to fetch the kids prezzies out of the Mex's boot.
wetandwindy2
Apr 2006
25-12-2010, 01:41
same as me had to turn the heater down a tad but got antifreeze in it anyway
wetandwindy2
Apr 2006
25-12-2010, 01:42
should you not have antifreeze in your system anyway as it helps to prevent corrosion in the system read that somewhere
escort new boy
25-12-2010, 02:14
RS2000CUSTOM
3? he finished work at 1, can imagine double figures by the time he posted.
Told you to sort it you ****, on the brighter side bout time you stuck a cossie in
